Help in regards of oversized bearings...
  • FRCFD5
    • Nov 2006
    • 22
    Does anyone know where to get .25mm oversized rs2 bearings?
    My project has been on hold for the last six months because of it .....
  • JP
    • 1858
    In the UK yes but not cheap they work out a lot more expensive than stock at around UK£260-80 the last time I checked from the KS distributor for just the mains and big ends no thrust washers. I try and avoid using them if there is a good crank available as normal ones are £220 including thrust washers.
    UrS6 Stroker + HTA3586 =
    • FRCFD5
      • Nov 2006
      • 22
      hmmm, already invested into a 92.8mm crank....
      • FRCFD5
        • Nov 2006
        • 22
        anyone use ACL rod/main bearings?
        • FRCFD5
          • Nov 2006
          • 22
          Found oversized Kolbenschmidt bearings in Germany!....phew
          • pasbogdan
            • Sep 2009
            • 1160
            • Country: Romania
            why oversized?Cranks are like speed bumps.You find one almost everywhere.
            Almost any 10/20v 5 piston crank will fit.The old cranks are 2 oil holes(i think they are better than new 1 oil hole)
            KS bearings should be around 180-200eur for both main and big end.If you are interested i can ceck for prices.
