Bearing girdle or not???
Unfortunately the only two companies I would trust to line bore/line hone in the UK (both do hundreds of race engines per year) neither of the two was interested in machining two different densities of material as it causes the blades to skip on the transition. So they could not gaurantee the job hence taking the route to strap the caps on mine.UrS6 Stroker + HTA3586 =
On a side note about diesel blocks. My 95.5mm ACV crank is a lot lighter than the ABY, counter weights are thinner. I was thinking diesel cranks would be heavier if anything.ABY S2 stroker (work in progress)
B5 1.8T quattro
B4 2.3 (decommissioned)Comment
Yes, it's propably difficult to get it good. That in the pic is done in finland but I have no clue what motorshop has done it.Unfortunately the only two companies I would trust to line bore/line hone in the UK (both do hundreds of race engines per year) neither of the two was interested in machining two different densities of material as it causes the blades to skip on the transition. So they could not gaurantee the job hence taking the route to strap the caps on mine.
BMW 740iA e38 - ProjectComment
Strange my 95.5mm crank weighed 22kg and the Stock AAN weighed 20kg so I knife edged the diesel crank to bring it down to 20kg.UrS6 Stroker + HTA3586 =
Where did you see the signs of the block twisting? Was is something you could measure or wear patterns or something else?After spinning our local dyno to the tune of 755hp, we took a very close look at things and discovered some interesting damage. We had actually twisted the block and destroyed the passenger side motorsport spec motor mount. As a result we've torn everything down and launched a multi-pronged effort to cure these issues.Comment
Sorry, looks are deceiving and I was assuming. I just weighed them up.
ABY=19.2 ACV=19.7 (when weighed without rags sitting on top)
Side by side, wieghts on the ACV crank appear a lot thinner but they are slightly longer.Last edited by Pat D; 3 March 2012, 00:35.ABY S2 stroker (work in progress)
B5 1.8T quattro
After tearing down the motor, a machine shop did measurements across the top of the block. They also measured the bore down the middle of the block. That is where the twisting was revealed. The crank was not damaged.
Hp, wit dakine twist not from Evahboost, MaguireComment
First for everything I guess. The only difference I can see is the added trigger plate and the weight, hope they didn't stinge out on material or strength
I don't think anyone has attempted a 20v/stroker conversion here in OZ. Would be good to know where the handful of S2 owners in OZ are. Last I heard there were about 5 left out of the 20 imported.ABY S2 stroker (work in progress)
B5 1.8T quattro
