Bearing girdle or not???
  • caterpillar
    • 2480
    Originally posted by Mcstiff
    Hank Iroz in UT has commented on how much beefier the "tall deck" block is. Wish we had more in the US (we only got them in the 10v vans).
    all diesel verson does have the talldeck block.. audi/ volvo 850/v70.and the 10v petrol in vw eurovan/ transporter
    • JP
      • 1858
      Originally posted by Thuppu
      This is even more extreme, full cromo bearing caps.
      Unfortunately the only two companies I would trust to line bore/line hone in the UK (both do hundreds of race engines per year) neither of the two was interested in machining two different densities of material as it causes the blades to skip on the transition. So they could not gaurantee the job hence taking the route to strap the caps on mine.
      UrS6 Stroker + HTA3586 =
      • Pat D
        • Dec 2011
        • 748
        • Country: Australia
        On a side note about diesel blocks. My 95.5mm ACV crank is a lot lighter than the ABY, counter weights are thinner. I was thinking diesel cranks would be heavier if anything.
        ABY S2 stroker (work in progress)
        B5 1.8T quattro
        B4 2.3 (decommissioned)
        • Thuppu
          • 4115
          Yes, it's propably difficult to get it good. That in the pic is done in finland but I have no clue what motorshop has done it.
          • quattro84
            • Mar 2006
            • 947
            I thought Jens Eklund had something similar done on his IL5.
            Edit: Yes by Snarskogen mechanik.
            On newer engines they rework the bores before cracking the main caps from the casted block.
            • JP
              • 1858
              Strange my 95.5mm crank weighed 22kg and the Stock AAN weighed 20kg so I knife edged the diesel crank to bring it down to 20kg.
                Ditto my crank was 22 kg
                • JariP
                  • 192
                  Originally posted by urs4guy
                  After spinning our local dyno to the tune of 755hp, we took a very close look at things and discovered some interesting damage. We had actually twisted the block and destroyed the passenger side motorsport spec motor mount. As a result we've torn everything down and launched a multi-pronged effort to cure these issues.
                  Where did you see the signs of the block twisting? Was is something you could measure or wear patterns or something else?
                  • Pat D
                    • Dec 2011
                    • 748
                    #24
                    Sorry, looks are deceiving and I was assuming. I just weighed them up.
                    ABY=19.2 ACV=19.7 (when weighed without rags sitting on top)
                    Side by side, wieghts on the ACV crank appear a lot thinner but they are slightly longer.
                    B5 1.8T quattro
                      Acv ? What engine is that??
                      • urs4guy
                        • Dec 2007
                        • 192
                        After tearing down the motor, a machine shop did measurements across the top of the block. They also measured the bore down the middle of the block. That is where the twisting was revealed. The crank was not damaged.
                        Hp, wit dakine twist not from Evahboost, Maguire
                        • Pat D
                          • Dec 2011
                          • 748
                          #27
                          Acv is late model 2.5 diesel from a transporter.
                          B5 1.8T quattro
                          • Pat D
                            • Dec 2011
                            • 748
                            #28
                            Turbo diesel
                            B5 1.8T quattro
                              Hmm well your using a VW base not the Audi shared AAT / AET base
                              The AET / AAT crank has a different part number to the ACV so your doing a stroker using a crank thats a bit unknown.
                              Interesting the crank is lighter
                              • Pat D
                                • Dec 2011
                                • 748
                                #30
                                First for everything I guess. The only difference I can see is the added trigger plate and the weight, hope they didn't stinge out on material or strength
                                I don't think anyone has attempted a 20v/stroker conversion here in OZ. Would be good to know where the handful of S2 owners in OZ are. Last I heard there were about 5 left out of the 20 imported.
                                B5 1.8T quattro
