Blue smoke ! Help!
  • audinut
    • Jul 2009
    • 2195
    Originally posted by gavs20v
    Did you tint the new fogs and indicators yourself or are they aftermarket items?
    i did them myself
    NOT a car dealer! just an S2/RS2 enthusiast
    • Golfboy666GTI
      • Sep 2008
      • 571
      • Country: New Zealand
      #77
      Originally posted by audinut
      Hi all just wanted to update this.
      I removed the downpipe after some advice and found some oil residue on the hotside of the turbo , managed to set a turbo from Sonic on here and the problem has gone !
      So a massive thanks to all who commented or pointed me in the right direction, the advice on the forum is second to none
      found this on the old turbo ! nice use of a 5 pence piece NOT!
      Hi, what do you mean "managed to set a turbo"
      So your issue was with your Turbo and nothing else? Im asking because I have a simular issue.
      1980 VW Golf GTI Track Car
      1995 Audi RS2
      • audinut
        • Jul 2009
        • 2195
        my apologies it should read (managed to get a turbo) , if your having similar issues whicp the down pipe off and look for a black residue i have picture of what mine looked like if you need them
        • audinut
          • Jul 2009
          • 2195
          OMG i really should read before i post !! ^^ WHIP ^^
            You can edit your own posts you know
            • audinut
              • Jul 2009
              • 2195
              every time i try the screen just jumps ??
                Same here, you have to refresh the page first for some reason
                • Zeus
                  • Jul 2007
                  • 70
                  • Country: Belgium
                  #83
                  Post picture please!
                  I'm having similar issues, also suspect the turbo, but I think mine is leaking on the compressor side (My inlet ducts have a lot more oil in them then yours...)
                  Could be the valve guides too on my car tho, but i suspect the turbo
                  Compression was ok btw
                  Car is using about 1 ltr oil approximately each 1000 km so not good
                  • Zeus
                    • Jul 2007
                    • 70
                    • Country: Belgium
                    #84
                    Btw, did you reuse or renew the turbo gaskets and bolts when you made the switch?
