As it states above the drivers side engine mount has snapped at least one bolt. Its the bolt that goes through the engine mount into the block
. My question is Has anyone come across this before?. It looks like it may be possible to brase the engine at the top and drop front of the sub frame down to access the block to remove the offending bolt. Next question, To do this I will need to remove the oil filter housing and the oil feed hose. So I will need gasket's for these parts. If there is anything ellse I will need could you let me know so I have everything to hand.
Any advice at all will be a great help.
Thanks in advance
Gary
. My question is Has anyone come across this before?. It looks like it may be possible to brase the engine at the top and drop front of the sub frame down to access the block to remove the offending bolt. Next question, To do this I will need to remove the oil filter housing and the oil feed hose. So I will need gasket's for these parts. If there is anything ellse I will need could you let me know so I have everything to hand. Any advice at all will be a great help.
Thanks in advance
Gary
