380 to 400 hp AAN - advice
    Two questions lifted from your full post above, can you expand on why you prefer the dual mass flywheel over a 3b one ? Is it possible to trim enough off a euro front bumper to fit an Apikol FMIC for a US urS6 to allow it to fit a european car ?, or will the bumper need too much taken off it to still stay in one piece ? At all, what does a european urS6 owner use when they want a decent FMIC on a euro UrS6 ? Thanks.
    Probably 3 or 4 questions there, not 2. But who's counting?
    1. SMFW vs DMFW. Personal preference maybe but being an engineer, I believe in the science behind the DMFW and its purpose to help prevent load shocks to the drive train (transmission gears, 2 prop shaft CV joints, two sets of crown and pinion gears and 8 axel CV joints). Here is some DMFW info that I put together a while back:
    2. An Apikol FMIC, with its 3" core, behind the much thicker NAmerican bumper *just* fits with a minimum amount of trimming. The Euro bumper fits in close to the body by about an inch (25 mm - ish) so I don't think it would work (core is too thick). Here is some C4 UrS bumper info that I have put together to show the differences between NAmerican and Euro and UrS4 and UrS6 bumpers:
    3. Audifans.net has a good write-up of a DIY FMIC with 2.5" thick core with a Euro bumper (and even then the "Euro" bumper has to be trimmed to get enough room for the FMIC):
    • Kim1978
      • May 2007
      • 12
      Originally posted by prj
      The only reason this is so, is because of how people map cars. Nothing to do with the turbo maker.
      If you map a K26/K27 to a constant 1.5-1.6 bar, you will have a very flat torque curve.
      People map them to 1.9 bar usually though, and obviously it can't flow 1.9 bar at 7000 rpm, that would be in excess of 500hp on a standard head.
      It's only a question of mapping.
      The problem with a GT is, that if you took a turbo with RS2 turbo sized peak flow and ran it to 1.9 bar with huge taper all the time, it'd fall apart, whereas a KKK can keep going for years.
      Dimitri, this is exactly the point I am trying to make.
      I had an UrS6 with a high peak boost that tappered signifcantly afterwards. The engine charachter was explosive at first to become 'lame' at the top end. It was a noticable feeling when the boost dropped and you could really feel how the 'pulling' become less pronounced.
      This is how I want my power curve and torque curve to look like. Less stress on the conrods also. Dimitri, this could be achieved with some less aggresive tuning in the mid-range right?
      • prj
        • Mar 2010
        • 6308
        Yeah, can be done.
        Always a question of having a certain rev range with a flat torque curve though.
        On these engines, if you can do 3000-3500 rpm you're doing pretty good.
        That can be 3500-7000, or it can be 4500-7500, all depends.
        • A1QSHIP
          • Aug 2004
          • 975
          Quote
          Thanks.[/QUOTE]
          You might try this for a european URS6
          http://www.034motorsport.com/turboch...r-p-21224.html
          HTH,Chris
          "Nulla tenaci invia est via"
          • byd1380
            • Aug 2009
            • 269
            #20
            I have just fitted FMIC to my S6, it was a nightmare, I though I had loads of room but didn't. I'll be updating pics in the next few days.
            Ivan
            • Wrath
              • Jan 2011
              • 779
              Only option I have found is this:
              http://www.ebay.de/itm/Ladeluftkuhle...item1e55ce4beb
              But then its 1399€ and that´s just scary...
              1995 Audi S6 - AAN (~350hp)
              2008 BMW 530xd (235hp)
              2011 KTM 990 SMR - custom tuned (120whp)
