Car is a 3B, RS" spec MRC mapped, missfires badly at anything other than very small throttle opening. At medium throttle boost comes up then drops then comes up again etc as if ECU boost control is being switched on and off.
If car is held at fast idle seems like the ignition is being switched on an off (same thing really).
When the codes were pulled the engine was not running and the Lambda was unplugged so I guess its just the 00533.
Control Module Part Number: 857 907 404 B
Component and/or Version: MOTOR PMC 1
Software Coding: 0261200453
Work Shop Code: 1267356261
3 Faults Found:
00533 - Idle Speed Regulation
10-10 - Adaptation Limit Not Reached - Intermittent
00525 - Oxygen Sensor (G39)
03-10 - No Signal - Intermittent
00513 - Engine Speed Sensor (G28)
03-00 - No Signal
3 Faults Found:
03-00 - No Signal
