Boost test
  • Bullysteeth
    • Jan 2012
    • 830
    Boost test
    Easy part
    And the hard part
  • Azman
    • Sep 2005
    • 3205
    mate if yo need one i have a 3b one in good nick in the shed
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
    • Bullysteeth
      • Jan 2012
      • 830
      will it fit the aby, and i now have a bigger problem, since i done the leak test me car somked like **** then got hot and the fan didn't kick in, i only did 22psi test, WOTS WRONG NOW
      Ha Ha i just had the stat out and boiled it and guess wot, stayed shut, strange how one thing leads to another and another with these older cars, so back to the smoke, well it was more white and thin than the oily blue !!!!!!!!!!!!!!
      • Tonybolony
        • Dec 2011
        • 636
        A few weeks ago you said your 710 was 'broke with a capital F' - if you havn't got around to changing it yet, is it possible that the pressure test has lifted it off it's seat and it's now stuck open? If so would that drastically affect mixture to the point that it will smoke??
        Just a thought?
        • Bullysteeth
          • Jan 2012
          • 830
          Just a thought?
          Fitted a new one mate from TPS, seems more like water and antifreeze smoke than oil,
          did a compresion test, all ok there, no gas in the coolant, will see wot happens when i fit the new stat bud, could it be the water cooled turb leaking into the exhaust
          • Tonybolony
            • Dec 2011
            • 636
            Fingers crossed that it aint the turbo Bud. Just out of curiosity- how long did it take to get at, and remove the 'stat?? I need to change mine, but a bit concerned about snapping the bolts, and every time I think about having a go- Bomber Command comes up with another project for me
            • Bullysteeth
              • Jan 2012
              • 830
              not to long to whip it out but i had to remove the PAS pump so i could see anything
              • Tonybolony
                • Dec 2011
                • 636
                That's what I thought
                Not a job I want to start in the evening then- it's gonna be a weekend job, and I cant do it this weekend, cos I'm gonna be watching Wales win the championship
                Oops- don't suppose I'm allowed to do Politics on the forum
                • prj
                  • Mar 2010
                  • 6308
                  That's why when you boost test you block the PCV.
                  So you don't blow oil past the seals and get loads of smoke.
                  • Bullysteeth
                    • Jan 2012
                    • 830
                    Dooh bit of a Homer moment,i was in such a rush i forgot, cheers prj
                      3B IC is a bit smaller than the ABY one.
                      • andy10v
                        • 5996
                        And the in pipe is different, I had no problem going 3b-aby, just cut the hose shorter, I think you would need a 3b boost hose as well.
                        Sold ABY-stock
                          Yes that's correct. IIRC the bolts are slightly different too, but I went 3B to ABY first then ABY to RS2 then RS2 to Ebay Biggie then Ebay Biggie to Wagner reversed... so not surprising I can't remember!
                          • Knight Rider S4
                            • 3541
                            I have a ABY one for sale if you want
                            93 S2 Avant Parting
                            91 URQ RR
                            02 A4 tdi Avant
                            • carboRS2
                              • Apr 2011
                              • 105
                              • Country: Spain
                              Originally posted by Bullysteeth
                              Easy part
                              And the hard part
                              Hello Bullysteeth,
                              I'm in the process of changing valve cover gasket and while removing throttle body found a scratch in the rubber hose.
                              Prj already adviced to do a pressure test but wasn't sure how to do it.
                              Now with your pictures is much clear how it's done.
                              Is an oil filter can what you've fitted into the maf hose?
