Unlike the two pistons that clearly showed something dramatic had happened with the colour differences on the ceramic coating, the combustion chambers are all the same with no signs of anything nasty happening.
Head Off - AGAIN
Doug, i would be interested to see how your rings have bedded in. Cant beleive there are no honing marks?? I hope it doesnt perform like last time too, as that turbo is making your/my car almost undriveable. I was gonna take it off today, but couldnt be arsed. Will do it soon tho. What you gonna do about headgasket then?? Just fit both gaskets or remove the rivets and make a custom multi-layer one?? Thats what I would be tempted to do. I must do that oneday when i have some more cash.sigpic
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nmComment
Tom - the honing marks are still there - they are not as visible asd the first timr I took the head off so I think the drive it hard to bed in method must work really well.
No hurry for getting that turbo off - hopefully get the new turbo built next week though.
I have made a thicker headgasket using the 2 internal layers of a second headgasket. The CR will be low now! I reckon 8.0 (maybe lower):1 - who cares what off boost is like! It is on the car now anyway. Just need to get all the new bits plumbed in adn that PS pump relocated.S2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8Comment
Mark, that's great news dude!
This means your problem only was the pistons sharp edges and the knock Mihnea heard wouldn't have done any damage at all if the pistons didn't have that problem.
This is very important, 'cause if for any reason it will happen you hear some knock again, you know that if it isn't so severe and you lift off the throttle whitin few seconds, your engine will be totally fine.
MarcoComment
In the way of reliablity i meant!Originally posted by Doug_RS2I hope it doesn't perform like before - it will perform a lot better this time - lots more advance (lower CR) and more lower down torque (changing turbo coldside).Was a '93 3B, Dont ask now tho......
Roger,Originally posted by Audi_CQCould the oil jets on cyl. 1 and 5 be blocked and cause higher temp on those pistons?
Cheers,
Roger
I did wonder about that, but didn't check them yet, I would have thought that I would see evidence on the undersides of the pistons, and possibly top of the rods, of overheating. But there was none they looked like new
all heat damage on the top.
I can check them easily enough though, I am getting good at stripping the engine
Doug, not meaning to hijack your thread either, will keep quite now
Thats it, im taking my head off now and gonna fit a custom headgakset, also do the ARP stud thing too
Should have done all this when i rebuilt it, but didnt have the money then
Audi UR Quattro
Keep up. Pah. I wont be content with just 'keeping up'. It needs to put me in the back of my seat and hold me there.sigpic
Audi UR Quattro
Stroker report
I'm interested to read your report. I now actually have in my possession an AAF 2.5l block. I plan to change the pistons and conrods, but use the block and crank.Originally posted by PisobikerP.S. If you guys have a little bit of patience I'll soon edit a detailed report of the stroker building.
So far I'm aware of some of the issues involved, at least with my block. Looking at the block and a 10vt MC headgasket, I can see that one of the oil return holes needs to be blocked by welding or plugging, and another part of the block needs to have some material added because a passage in the gasket hangs over the edge of the deck. Another important thing that's missing is the hole for the timing pin sensor. All this in addition to having to add the oil squirters. And the 20v head needs larger headbolt holes put in. But at least one of the hard parts is done, I actually have the block and crank!
Cheers,
KenKenneth
1990 Coupe quattro
1991 200q20v x 2
1985 4ksq 20vt project
1986 Coupe GT 10vt project
2006 Honda Ridgeline
1998 Honda VFR800FIComment
try and keep up!
