3b pin swap, whats pin 50 for ???
  • ian4455
    • Nov 2010
    • 787
    I've completed my 3b pin swap today but what is the new wire to pin 50 for ?
    VSS - speed signal, why do i need this ?
  • Kryptonite
    • Aug 2010
    • 63
    you don`t need this pin.
    • Jonas_R
      • 3780
      • Country: Denmark
      Can't remember what the ECU uses it for but you it is white/blue wire and you can fint it in one of the plugs in the instrument cluster.
      Sleeper S2 Avant +450
      A6 Avant 2.7t Stage 3
      Audi S2 Coupe RS2'ed
      • ian4455
        • Nov 2010
        • 787
        just wanted to know why its labeled in the pin swap and why its needed, launch control maybe ?
        • quattrostyle
          • Oct 2006
          • 6229
          AFAIK that could be used for launch control indeed.
          • prj
            • Mar 2010
            • 6308
            Yes, you do.
            If it's not connected you will get a code thrown up in the ECU and a few things won't work properly.
            • rs200
              • May 2009
              • 1398
              • Home: Croatia
              Originally posted by prj
              Yes, you do.
              exactly like that.
              when I do pin swap , first few days my VSS was not conected, because I couldn't find right wire. than I get some fault code every time on same speed.
              for example 30 ,80 ,120km/h , blink code lamp was flashed on 1second ant than gone.
              when I get right VSS wire, that problem gone.
              they would not be there, if they are not important !
              • ian4455
                • Nov 2010
                • 787
                ok which place to find the correct Blue with White Stripe wire then ?
