water pump
  • wigan11
    • Oct 2004
    • 23
    water pump
    my aux water pump does not work ive tested it it works when i put 12v to it and ive tested the plug there is 12v there put when i plug them to gether it does not work its a new water pump
  • Jay
    • Jul 2004
    • 599
    Check the earth circuit.. I can't remember if the aux pump is + or - switched and my data is up north so can anyone else answer that??
    • Doug_RS2
      • 3847
      is this the after run pump? Probably a fuse - common problem - can't remember which one in the box but check them all.
      • wigan11
        • Oct 2004
        • 23
        have checked the fuses there is twelve volts there but when u plug it in i get 12v of both terminals and then the body of the pump terns to the earth
        • Josh-stateside
          • 741
          An on-line resource for information on the Audi S2 manufactured between 1990 and 1995.
          There is a write up on it.
          try connecting 6 and 8 on the relay
