my aux water pump does not work ive tested it it works when i put 12v to it and ive tested the plug there is 12v there put when i plug them to gether it does not work its a new water pump
water pump
Check the earth circuit.. I can't remember if the aux pump is + or - switched and my data is up north so can anyone else answer that??Originally posted by wigan11my aux water pump does not work ive tested it it works when i put 12v to it and ive tested the plug there is 12v there put when i plug them to gether it does not work its a new water pump -
Originally posted by wigan11have checked the fuses there is twelve volts there but when u plug it in i get 12v of both terminals and then the body of the pump terns to the earth
There is a write up on it.
try connecting 6 and 8 on the relayI chose not to choose life: I chose something else. And the reasons? There are no reasons. Who need reasons when you've got quattro?Comment
