As per title, what solution have people used to support the factory radiator from rocking backwards and forwards when using the front mounted Wagner intake manifold ?
As the oem drilled bar / strap from the bonnet slam panel to the LHS of the oem radiator can’t be used with the new manifold and throttle body in the way.
Any photos of solutions arrived at ?
Thanks for any suggestions.
While the zip ties at the front and back of the radiator “tying" the rad to bodywork work very well, they look very mickey mouse.
