S2 1995 serious problems
  • david656
    • Mar 2012
    • 29
    Hi,
    I have absolutely 0 luck with cars, every one i've had just breaks.
    2 days ago after owning it 3 days i look under it to find there's oil dripping out of the underbelly tray thing under the engine, i get the tray out to find it covered in oil and oil appears to be coming from the front of the engine.
    So it's booked in the garage for Monday but i go to drive home from work today, i go to accelerate hear a kind of clunk/mechanical noise from what i can only thing is the front and back diff as comes from both ends... the exhaust makes a slight bang noise and the car will not accelerate past this point in any gear. although if you go through the gears will get to 60.
    this car is immaculate and looks to be well looked after i really hoped this one would last longer than 1 week
  • SteveH
    • 4460
    Your in Bristol, could be on oil leak and a boost leak, it shouldn't be too difficult to diagnose and there are a few members in Bristol
    91 Modded 3B
    14 A6 Avant Black Edition
      Have you checked to see where the oil is coming from?
      • david656
        • Mar 2012
        • 29
        thanks for support.
        I hope its nothing complicated ... i've lost so much money, time and sanity with cars in the last year i was hoping spending a good amount of money on a well kept example would show me love back haha like I say its booked in on Monday but i didn't know if there was anything to check for.
        • shaun5
          • 1610
          Have you been able to tell where the oil leak is coming from? Is it from the radiator side? Obviously it could be anything but recently ive seen 2 S2 with the oil pressure swich leaking.
          • david656
            • Mar 2012
            • 29
            i used to pinto's in capri's ! i've tried getting under it with a torch above it with a torch... alll i can say is the oil appears to be at the front of the engine and looks to be running down behind the belt on the front of the engine
            • RustyNut
              • 1433
              • Home: Zambia Current: United Kingdom
              Where in Bristol are you David?
              Old Stuff Reborn.
              • david656
                • Mar 2012
                • 29
                Hanham but will happily drive anywhere for a second opinion on what the heck is going on!!!!
                • RustyNut
                  • 1433
                  Go and see Leighton @ Pro-Garage in Warmley. He's an ex Audi technician, works mainly on Jap stuff but knows his Bavarian steeds also. His FB page for the address is https://www.facebook.com/pages/Pro-G...77151595691765 . If he's too busy you can try AllAudi in Brislington. Ask for Dean or Neil.
                  Old Stuff Reborn.
                  • david656
                    • Mar 2012
                    • 29
                    Thanks.... from what i can tell that pro garage is a paint shop, they refurbished my Ford Capri alloys for me and someone i went to school works there - i just never knew the name of their company!
                    i'll check them both out tomorrow
                    • RustyNut
                      • 1433
                      The spray shop is Restomod which is run by James. They share the premises.
                      Old Stuff Reborn.
                      • bluequattro
                        • 2960
                        If its that much oil is it wise to start let alone drive it?
                        Check oil level before going far.
                        What engine btw ?
                        • Big Lee M
                          • 2571
                          I think it might be your oil cooler by the sounds of it and a boost leak. Boost leak isn't a biggy really.
                          Just some finishing touches to do now
                          • david656
                            • Mar 2012
                            • 29
                            Its only a drip of oil with the pan off... i think a lot was sitting in that.
                            so.... on the floor there is maybe a 1.2inch circle max of oil
                            the oil level doesn't look to have gone down that much but put a glug of synthetic oil in this afternoon - its since that that the odd diff /power issue happened i used 5w 40 from the petrol garage on the grounds that any oil was better than none
                              You didn't leave the oil cap off did you?
