Any turbo experts or opinions please
  • ian4455
    • Nov 2010
    • 787
    Compressor side
    inducer = 57mm
    exducer = 84.6mm
    Turbine .70 A/R
    inducer = 60mm
    exducer = 70mm
    Compressor overall diameter of housing is a204mm with a 64mm outlet.
    What power can i expect at what rpm with this turbo ?
    Same ish size as a 3076r
    But a turbo is more than just the spec as they have different blade design and these yield different results
    • driftin jo
      • Sep 2007
      • 2222
      As above,
      It all depends on how old the technology / design is.
        What make is the turbo?
        • ian4455
          • Nov 2010
          • 787
          Holset
            So it's a hx35 then?
            • Billman
              • 4129
              500+ should be easy with that turbo
              Go Holset or Go RS4
              • my2000apb
                • Jul 2010
                • 637
                i think so
                BEAST '90 CQ 24v VRT / O1E / v8 rear, HOLSET SUPER 40 http://www.theprojectpad.com/viewtop...1&t=193#p37887
                DD '86 4kq BLAZE, swapping aba/16vT and O1E http://www.theprojectpad.com/viewtop...1&t=201#p38264
                  If its the case I think 450 to 500 is more realistic on super unleaded
                    What a question to ask on here ?
                    You’ll definitely get plenty of replies.
                    Kind regards.
                    • Billman
                      • 4129
                      Kind regards.
                      Go Holset or Go RS4
                      • ian4455
                        • Nov 2010
                        • 787
                        ok what about -
                        Compressor inducer 49mm, exducer 84mm. dia of compressor housing 184mm
                        Turbine .70 A/R
                        inducer = 60mm
                        exducer = 70mm
                        • Billman
                          • 4129
                          nooo too small compressor
                          Go Holset or Go RS4
                          • ian4455
                            • Nov 2010
                            • 787
                            Looking to limit around 450bhp,
                            another option is -
                            Compressor side
                            inducer = 54mm
                            exducer = 84.6mm
                            Turbine .70 A/R
                            inducer = 60mm
                            exducer = 70mm
                              Limit boost
