Any turbo experts or opinions please
  • prj
    • Mar 2010
    • 6308
    So why are you "looking to limit"?
    Torque breaks things, not horsepower. If you have some component that is not strong enough, then you limit torque.
    • ian4455
      • Nov 2010
      • 787
      Ok i'm looking at options with what ive got already to get my car back on the road. My engines basically standard
      Building a new engine but still collecting parts...
      • Acidburn
        • 13459
        easiest thing to do then is list up what exactly is on your car so people can advise you properly rather than just saying turbos and people having to guess what you've got to support it.
        • ian4455
          • Nov 2010
          • 787
          Originally posted by ian4455
          ok what about -
          Compressor inducer 49mm, exducer 84mm. dia of compressor housing 184mm
          Turbine .70 A/R
          inducer = 60mm
          exducer = 70mm
          Is this no good as a start point to set-up my VEMS ecu, good for say 380-400hp ?
            Don't understand what you are asking really you have a hx35, install and map it
            • Billman
              • 4129
              #21
              limit boost so that you can have 350-400 hp.
              Go Holset or Go RS4
                Why is he looking to limit though this turbo can easily run at a high potential on a stock bottom end
                Reading back through the thread I'm lost on why the 350-400 limit
                • Billman
                  • 4129
                  #23
                  he wants to limit it for starters
                  Go Holset or Go RS4
                  • ian4455
                    • Nov 2010
                    • 787
                    Sorry should have said, my rods are stock so don;t want to brake anything using a HX35. My injectors are 420cc.
                      But thats the point you wont break anything with that turbo and stock rods. to bend rods you need torque and a lot of it low down. If the guy mapping the car knows the engine this isn't a problem. It's all a lot of fuss for nothing.
                      • ian4455
                        • Nov 2010
                        • 787
                        ok thanks, I've nearly got my engine back together tonigit so I'll see if it fires up later this week !
