VEMS Idle diode question..help
  • ian4455
    • Nov 2010
    • 787
    Do you really need the idle diode when using vems ?
  • Nuno Cristiano
    • Aug 2010
    • 421
    • Country: Portugal
    If i remember well VEMS use internal diode flyback to control solenoids ( high power current output ). So, if you put other diodo in parallel with solenoid you reforce flyback current when the power Mosfet is turn OFF.
    .: MINI Cooper D 08' :.
    .: Audi Coupe Quattro 20V 91' :.
    .: Audi Porsche RS2 95' :.
      hit the search!
      • ian4455
        • Nov 2010
        • 787
        just been on efi website reference their set-up for the s2, there's a diode adaptor lead included. When i used vems on the audi abz engine no diode used, maybe because its a different idle control valve! Reason i ask is i'm using vems on my s2 and haven't the diode.
          The diode is optional but idle control is greatly increased with it
          • ian4455
            • Nov 2010
            • 787
            ..just been looking at the thread, thanks helpfull info.
            what diode would be recommended if i would source from somewhere like RS components ?
              Cant advise I bought the efi express cable!
              • Nuno Cristiano
                • Aug 2010
                • 421
                • Country: Portugal
                Simple 1N4007 can do it
                Or SMD diode S1G.
