Do you really need the idle diode when using vems ?
VEMS Idle diode question..help
If i remember well VEMS use internal diode flyback to control solenoids ( high power current output ). So, if you put other diodo in parallel with solenoid you reforce flyback current when the power Mosfet is turn OFF..: MINI Cooper D 08' :.
.: Audi Coupe Quattro 20V 91' :.
.: Audi Porsche RS2 95' :. -
just been on efi website reference their set-up for the s2, there's a diode adaptor lead included. When i used vems on the audi abz engine no diode used, maybe because its a different idle control valve! Reason i ask is i'm using vems on my s2 and haven't the diode.Comment
