RS2 smoking grey on start up (with video)
  • Golfboy666GTI
    • Sep 2008
    • 571
    • Country: New Zealand
    Hi guys I am after some advice as to why my RS2 is smoking grey on warm start up?
    When the car is stone cold there is nothing, but up to about 4 hours after its last run it smokes grey for up to 30 seconds:
    Any ideas what it would be? Turbo? Rings? Valve guides?
    1980 VW Golf GTI Track Car
    1995 Audi RS2
  • SteveH
    • 4460
    What's the mileage on the RS2? Do you notice any smoke on the overrun? You may need to get someone to follow you to check for smoke whilst moving.
    It could be valve stem seals or the hot side seal on the turbo. I'm sure someone on here will be able to suggest a few tests to identify what's causing it. It doesn't look bad from the video though. Is everything standard on the car - turbo, breather system, etc?
    91 Modded 3B
    14 A6 Avant Black Edition
    • pixsaudisex2
      • Sep 2004
      • 3110
      Oil gives off blue smoke white smoke is water. Just looks like nomal to me. Mind you I grew up around rover. Cars lol.
      • Golfboy666GTI
        • Sep 2008
        • 571
        The car is standard apart from a K&N replacement filter, its done 229,000kms and is daily driven. I cleaned the flame trap about 2 years ago (wasnt too bad) and did it again last month (nothing much has changed). It doesnt smoke on overrun.
        1995 Audi RS2
        • Golfboy666GTI
          • Sep 2008
          • 571
          It doesnt use any coolant though.
          1995 Audi RS2
          • veneto rs2
            • Jun 2006
            • 1022
            • Country: Veneto
            With that amount of kms I would say valve seals.
            If they are worn oot you'll have some bit of oil getting on the pistons cealings and hence burnt on first cold start up.
            Stefano
            http://www.audisportclub.com/
