can't find what 's wrong, help needed
All is clear now,many thanks.He is talking about the dash pot (see photo below). It wasn't adjusted properly to easy the throttle closing so it was slow and gentle (so as to not bang shut). He adjusted the dashpot position and then rotated the throttle position switch so it registered open/closed properly.
its just a shame that my car is still running the same after doing all those things.
How much were inserts for im? Do you have part numbers too? Goto get my injectors out as one is playing up after cleaning and is a likely boost leak location on mine too.Greg
Greg the old ones are feel like they are made of glass,and the new ones are made of cheese,so be very gental.they are cheap enough so buy a couple of spares.
Take the IM of, its the only way,and you must make sure that the threads in the IM are clean.Newsh helped me do mine, and it was not straight forward,we used a thread file to clean the IM and a brass injector seal to clean out the threads,one or two where still tight.
Good luck
