N75 connection missing on RS2
  • s2_bo
    • Oct 2005
    • 6067
    #31
    So you actually have both valves fitted at the moment, they prob left the stock DV on to block the hole from the maf - turbo hose.
    Well that makes it simple,
    Just remove the BOV, and plug your BPV that we could see in the earlier photos in to that connection.
    Then make sure that its also connected to the vacuum feed to the inlet manifold, at the moment that connection is probably on the BOV. (the small hose)
    Good luck.
    91 S2 coupé - RIP
    98 S8 - Luxury barge
    • wowow
      • 123
      • Country: Hong Kong
      #32
      The BPV is stock. It's the light that makes it look silver.
      ________________
      RS2-95
      • wowow
        • 123
        #33
        Yes S2-bo, my car has both the bov and BPV fitted at the moment. The PO fitted the bov and just left the BPV ( or all DV ) there. What a mess !
        ________________
        RS2-95
        • wowow
          • 123
          #34
          I guess it make sense to plug everything from the bov to the bpv. But I still have a hose missing from the N75.
          ________________
          RS2-95
            Old forum pic with dodgy spelling
              Or these (from this: http://forums.quattroworld.com/s4s6/msgs/20987.phtml )
              • wowow
                • 123
                #37
                Thanks guy. Will try to make the changes in the next few days.
                ________________
                RS2-95
