small quiz: where is this membrane from
  • Avantus
    • Sep 2007
    • 941
    • Country: Belgium
    Quick quiz for you all;
    where does this membrane come from
    It's ripped out obviously, since it had a tear in it (2nd picture on the bottom -> curled and dark/burned)
    Well it isn't the WG membrane. Other candidates include the BPV, the fuel pressure regulator and the pressure regulating valve (PCV system).
    • Avantus
      • Sep 2007
      • 941
      • Country: Belgium
      Well you pretty much mentioned them all
      but it's from the PCV valve, correct. Ordered it to replace it precautionary, and cut the back lid of to see the inside... to my surprise
      the membrane was ripped over 2cm.
      that would mean I was pulling CV oilfumes under vacuum into the intake, correct?
        Originally posted by Avantus
        but it's from the PCV valve, correct. Ordered it to replace it precautionary, and cut the back lid of to see the inside... to my surprise the membrane was ripped over 2cm. that would mean I was pulling CV oilfumes under vacuum into the intake, correct?
        Yes, probably. And by PCV valve you mean Pressure Control Valve as shown below:
        More info on the crankcase ventilation system here: http://forums.quattroworld.com/s4s6/msgs/22506.phtml
        • Avantus
          • Sep 2007
          • 941
          • Country: Belgium
          Cool info
