Sand blasting
    the irony yes JP is RWD19T
    • JP
      • 1858
      Maybe we should change my username from RWD19T to JP?
      UrS6 Stroker + HTA3586 =
      • JP
        • 1858
        Originally posted by Tonks4x4
        May I ask what kit you use for aqua blasting? And what psi it runs at?
        Running a massive freeflow 3phase hydrovane and sealed wetblast/aquablast cabinet from vapormatt with a 30cfm gun. Including the 10hp digital 3 phase converter to power the hydrovane all 3 came in just shy of £10k installed.
        I normally run a fine finishing media with 55-60psi. This gives a shiny satin cast finish.
        Can run upto 80-90psi but that starts to peen the surface even with a fine media so only good if doing stripping which I prefer not to use it for. Attached is a pair of scooby heads I just finished porting today.
        The marks around the cleaned up exhaust port is waterspray out the airlines when drying which wipes clean with a rag and brake clutch cleaner
        hth
          That is actually a good idea
          • Sonic
            • Jul 2006
            • 5514
            #35
            Or JNL-Racing, just to confuse things further
            S2Forum.com Administrator
            • JP
              • 1858
              I think JP will be fine if it is possible Sonic
              *edit
              • Thuppu
                • 4115
                Wow, I really have to buy a ported head from JP some day.
                • quattro84
                  • Mar 2006
                  • 947
                  Indeed, time for a group buy
                  • europeanme
                    • Oct 2005
                    • 3817
                    how freaky is that...as I was reading this thread about JP's username and it changed before my eyes!!!...
                    • Rikki Kitto
                      • Feb 2010
                      • 6276
                      Haha spooky times indeed
