Guys,
2nd post already!
On my Dupré Motorsport tuned RS2 originally F2CS spark plugs where used. I found the heat range very cold with respect to the original F5DP0R spark plugs and just used the latter ones, also on the advice of the only RS2 specialist in Holland.
I am experiencing some problems under full boost, intermittant cut outs. I cannot determine if it's boost related or ignitation related. The car has new spark plugs, new N75 valve, new spark plug connectors, new lambda sond and a new thermostat.
I read on the German www.rs-zwei.com that high boost can blow away the spark and you can prevent this problem with colder plugs gapped to 0.4mm instead of the regular 0.6mm...
Anyone know if the above is true and if this could cause problems under high boost?
My car has been tuned to 380 HP with a hybrid turbo, head work, et cetera. Don't know/have complete build spec.. I can give it about 90% on the loud pedal without these problems occuring. I noticed the problem growing very worse after a lap on the Nordschleife. Seems to be temperature related...
No error codes on the car!
TIA,
Adwo
2nd post already!
TIA,
Adwo
