Hi! Changed my sparkplugs yesterday, the engine won´t start except when I´m giving it full throttle.
Are you sure that you didn't disconnect something, e.g. Throttle Position Switch or something (a ground) during your sparkplug change and then forget to reconnect it?
Yes sir I´m sure Changed back to the old platina plugs and everything worked again
What´s the stock gap on these plugs ?
What´s the symptoms of running with to small gap ?
Yes sir I´m sure Changed back to the old platina plugs and everything worked again What´s the stock gap on these plugs ? What´s the symptoms of running with to small gap ?
The Bosch F5DPOR plugs are set at 0.6 mm if I remember correctly. If my math is right, 0.6 mm is 0.0236 inches (at 25.4 mm/inch) or 23.6 thousanths. On that basis, I would say running too LARGE a gap (with weakish coils) = no spark = no start?
The Bosch F5DPOR plugs are set at 0.6 mm if I remember correctly. If my math is right, 0.6 mm is 0.0236 inches (at 25.4 mm/inch) or 23.6 thousants. On that basis, I would say running too LARGE a gap (with weakish coils) = no spark = no start?
okey.. so 0,6mm from the factory ?
Well, will try my NGK´s with 0,6 down to 0,4.. otherwise those plugs goes down in the trash and I´ll continue runnin bosch platina
Only plugs I've had repeatedly fail are f5dpor's. I now run ngk race plugs heat range 9 gapped at 0.7mm and those have been fine on one set for 35+k miles on two engines and numerous dyno and quarter mile sessions at 500+hp
Tri electrodes work fine but are more prone to pre ignition.
Fair play, can't argue with that, you more than know your stuff when it comes to engines and tuning. Are the NGK race plugs expensive? They last very well by the sounds of it!
Out of interest what failed on the F5DPOR's?
When I said they were the only plug I use in S2's I was referring to standard or chipped cars, obviously heavily tuned engines have different requirements. I take it there'd be no problem using the NGK race plugs in a standard engine?
1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.
