had a freaking TERRIFIC EVENING ON THE DYNO!!!!!! driving into the trailer tops ALL.
but, got some good solid data... and ended up 759AWHP/554 tq @ 38 psi, that is more power (22 hp) and less tq (14 ft) but with 2 psi less.
changes were old turbo had cast 63mm wheel and 1.10 hotside. new turbo has 67mm billet wheel and 1.25 hotside. we did log all of the runs for backpressure and will be looking into that as well.
pass 4
pass 5
then us being us, we deciding to forego 800 AWHP in favor of a 4 gear bash clutchless shifting. and its gonna be sofaking BADASS!!!!!! 3 days! we even turned the boost down in each gear, specially the 1-2 transition. 3-4 was pretty much as it will run.
pass 6
and yes, that is a 40 psi gauge. it holds right where the tuner Kevin Black says to hold it.
and messin around with runnin thru the gears with clutchless shifts on the dyno.
pass 4
pass 5
pass 6
