Advice on injector size and brand from experience?
  • Pat D
    • Dec 2011
    • 748
    • Country: Australia
    As per title, is there a prefered choice in injector brand and rating for 600-700HP from experience?
    I will be using an Autronic SM4 ecu.
    ABY S2 stroker (work in progress)
    B5 1.8T quattro
    B4 2.3 (decommissioned)
  • prj
    • Mar 2010
    • 6308
    Ev14..
    • Pat D
      • Dec 2011
      • 748
      Originally posted by prj
      Ev14..
      cc rating?
      B5 1.8T quattro
      • prj
        • Mar 2010
        • 6308
        750cc or bigger, assuming 4 bar fuel pressure.
          I agree then I would as I have this setup
          • europeanme
            • Oct 2005
            • 3817
            http://www.ebay.co.uk/itm/5-EV14-Vol...item5643cf7991
            my set up.....
            • terrybullwon
              • Mar 2006
              • 8782
              A good fuel system will also be required!
              Chef
              • Pat D
                • Dec 2011
                • 748
                I plan on using the standard pump feeding into the 034 1 litre surge tank in the engine bay, which has a 044 inside of that.
                Five o have 1000cc EV14's. Are there any issues with going too big with injectors?
                B5 1.8T quattro
                • prj
                  • Mar 2010
                  • 6308
                  1000cc EV14's will be fine.
                  2000cc's will be a bit worse than 1000 on low pulsewidths, but still manageable.
                  Bigger than that I would not recommend.
                  • JP
                    • 1858
                    Had a look at that one litre surge tank. Good idea but saying it will handle 700 at 6.2bar means I can't see it as a viable option for my turbo upgrade. Think I'll stick with a hefty intank one instead.
                    Other options on injectors are the ASNU ones custom made to spec using bosch plug bodies and ev14 internals to any desired cc.
                    UrS6 Stroker + HTA3586 =
                    • Pat D
                      • Dec 2011
                      • 748
                      Five O sent me an email reply recommending this injector http://www.ebay.com/itm/ws/eBayISAPI...e=STRK:MESE:IT
                      Sounds kinda good?
                      B5 1.8T quattro
                      • prj
                        • Mar 2010
                        • 6308
                        A lot of bold claims, but zero data.
                        Latency is not a very big issue, linearity is. Them claiming they are more linear than EV14 - well, let's just say I would like to see some graphs.
                        Just go with EV14's.
                        I don't even see why you would get 1400cc injectors, unless you are running E85?
                        On gasoline, 750cc is above the limit that the stock lines and a single 044 will handle. Any bigger is pointless without serious mods to the fuel delivery system...
                        • Pat D
                          • Dec 2011
                          • 748
                          Big claims is what I was thinking as well, not much there and no reviews.
                          I'm thinking of leaving the stock fuel line feeding into a surge tank in the engine bay with an aeromotive A1000 to the rail, should be able to support a decent amount of fuel?
                          B5 1.8T quattro
                          • Pat D
                            • Dec 2011
                            • 748
                            Will be on gasoline, but thinking of having a map for E85 as well
                            B5 1.8T quattro
                            • prj
                              • Mar 2010
                              • 6308
                              It's not that simple as "having a map for E85"...
                              E85 is a good fuel, but it's energy density is more than 30% lower, so your fuel delivery system would need to be able to handle up to 1000hp on gasoline, and that is not easy or cheap at all.
                              A single pump with stock lines will not do for sure.
