Advice on injector size and brand from experience?
have you emailed ryan at five O? He sorted me out with mine (and a few others) injectors...
he's a good guy....Comment
Does anyone have experience or know if these injectors perform well? Bosch 0280158827
ABY S2 stroker (work in progress)
B5 1.8T quattro
B4 2.3 (decommissioned)Comment
Pat,
One thing to add and if you go EV14's make sure you get the L version if your running a stock fuel rail....Attached FilesComment
Cheers mate, I have an aftermarket rail fitted that takes the standard length injectors. I've decided to go with a Bosch 0280158821 2200cc. Five-O have a modified version that makes them a longer injector to fit the rail
http://www.fiveomotorsport.com/2200c...58821-pigtails
B5 1.8T quattro
wouldn't 1000cc injectors be big enough for that? I mean you would need a min of 3 044 motorsport fuel pumps to keep up with the 2k plus cc injectors...
Just thinking that a smaller set must give better results long term than something that will likely never be much about 50% duty cycle at 4 bar rail pressure. Room to grow is great, but within reason.
Sent from my GT-N7105 using Tapatalk 2Comment
http://www.ebay.com/itm/Set-of-5-EV1...c30e44&vxp=mtr
This is the set I'm using. Dmitri had no problem to get them idle fine with stock motronic.
BMW 740iA e38 - ProjectComment
Here's a guide to roughly help with sizing and how I decided to use 2000cc injectors http://injector-rehab.com/shop/e85_injector_size.htmlABY S2 stroker (work in progress)
B5 1.8T quattro
Ok using that calculator of 1.47 factor increase in fuel requirements, 1200cc injectors will feed almost 800hp on e 85 at 3bar pressure. At 4 bar your over 900hp. Too small for you??
Did you change the BSFC to 0.65?
This Size Selection Guide is intended to help in determining what size injector to use in your application.
* Brake Specific Fuel Consumption: This is the amount of fuel consumed (in lbs. per hour) for each horsepower made.
This should be .45 to .50 for naturally aspirated engines
Supercharged engines should be between .55 to .60
Turbocharged engines.60 to .65
Rotary engines, estimate BSFC to be 0.6 to 0.7
For engines running methanol, double the appropriate gasoline BSFC (e.g. a rotary engine running methanol has a BSFC between 1.2 and 1.4)
** Maximum Injector Duty Cycle should be around 80% max for safe operation. This allows for some future horsepower increases.ABY S2 stroker (work in progress)
B5 1.8T quattro
