Too high boost pressure?
  • WidowmakerS2
    • Oct 2007
    • 354
    • Current: Norway
    Hi guys,
    I just fitted a boost gauge to my car, and I got some odd readings.
    The car is an original 3b, 3"DP+ Exhaust, Rs2 airbox, Homefries. No resirc valve.
    The gauge is a AEM -1 to +2.4 Bar.
    On ignition, the gauge recalibrates to account for atmospheric pressure.
    From what I've read I should be seeing 1,4 Bar on the gauge, instead I get 2 Bar
    Any ideas to what could be causing this?
    If at first you don't succeed, destroy all evidence that you tried.
    -CQ 3b "S2".
    Your car is chipped and ecu has a different map sensor.
      2 bar on a K24 turbo? even chipped you shouldn't be seeing these boost levels. Are you sure you haven't got a different turbo?
      • nip
        • Apr 2006
        • 1786
        • Home: United Kingdom Current: Abu Dhabi
        Stiffer wastegate spring
          no spring gives 2 bar by itself on the stock audi wastegate that i've seen. the 034 2.2 bar is 1.1 boost pressure plus a K24 doing 2 bar??
          • nip
            • Apr 2006
            • 1786
            My standard k24 is doing 2 bar for 350 miles
            • RoadKill
              • Dec 2004
              • 567
              i ran a k24 at 2 bar lasted a week befor it died
              service tec @ East Kent Audi
              S2 ABY
              B8.5 A4
              • driftin jo
                • Sep 2007
                • 2222
                Torn waste gate diaphragm, hose to waste gate split or come off and on the odd occasion the N75 fails and stops boost pressure going to waste gate, they normally fail open and you get spring boost, but not always.
                The thing that is puzzling is why your ECU is not cutting fuel to prevent engine death?
                More information is needed, did this start just after you chipped it etc,etc.
                  Exactly!
                  • nip
                    • Apr 2006
                    • 1786
                    Mines still going lol, but don't know why it boosts so high
                    • driftin jo
                      • Sep 2007
                      • 2222
                      You will also kill the turbo, comp wheel will explode as running very high boost and no recirc, when you shut the throttle the stress on the blades will be work hardening them, soon they will let go!
                      your intercooler and engine will be full of aluminium bits !
                      • driftin jo
                        • Sep 2007
                        • 2222
                        Disconnect the N75 (electrical connector) and tell us what your gauge reads
                        • RoadKill
                          • Dec 2004
                          • 567
                          i snaped the shaft right in the middle on mine was well lucky , did not blow oil ran the car for a week why i tryed to work out what had gone still got it in a box should take it to bits some time
                          S2 ABY
                          B8.5 A4
                          • nip
                            • Apr 2006
                            • 1786
                            Jo, if I disconnect the n75 should I see 5 psi? Also if it keeps on at 2 bar what would that eliminate?
                            • driftin jo
                              • Sep 2007
                              • 2222
                              you were lucky, no engine full of comp wheel debris .
