Quick fuel pump question!
  • Carfreak
    • Apr 2012
    • 225
    Hi everyone!
    Just wounder if it´s possible to use the stock UrS4 filter on the basket on the bigger 60mm basket for 044 pump ??
  • Thuppu
    • 4115
    No, the filter is not removable from the basket on UrS4/6.
    • Carfreak
      • Apr 2012
      • 225
      ah okey The company that shipped my pump forgot the send the filter with it
      Just have to wait then..
      • Thuppu
        • 4115
        Well, you don't necessary need the filter. There should be a filter inside the pump, at least on a genuine 044, if you look inside the inlet. But of course it's better if you get a proper filter(strainer) for the basket.
        Part number is: 895201531A
        • Carfreak
          • Apr 2012
          • 225
          Ah okey.. yes it´s a original bosch 044 pump.. well, my tank looks clean inside so I´ll go without the basket filter then..
          • Carfreak
            • Apr 2012
            • 225
            Tryed to remove the stock basket but can´t turn it anti clockwise :s
            What tool do u use to remove it ? I just tryed to remove it by hand..
              Fuel Pump Testing and Replacement Info
              There are removal hints in this DIY:
              General C4 UrS Fuel pump info:
              General C4 UrS engine bay info:
                Does that strainer fit in the '93 Audi V8 Fuel pump 60 mm reservoir(cradle) part #: 895 201 779 H?
                  C4 UrS 044 Bosch Fuel Pump Install DIY
                  Originally posted by Carfreak
                  Hi everyone! Just wonder if it´s possible to use the stock UrS4 filter on the basket on the bigger 60mm basket for 044 pump ??
                  Here is a step by step C4 UrS 044 install DIY:
                  • Carfreak
                    • Apr 2012
                    • 225
                    http://forums.quattroworld.com/s4s6/msgs/20355.phtml
                    Awesome!! I will make a similar tool then and try removing my stock basket
                    • Thuppu
                      • 4115
                      Yes, they are a pair.
                      Don't dremel the pump as in the DIY instruction. Use a hot air gun to heat up the reservoir(basket) collar, then you can just press in the pump.
                      • Carfreak
                        • Apr 2012
                        • 225
                        Just a question.. shouldn´t the pump prime for like 5sec with the ign on ? Mine does only come on when starting the engine, at the third ign selection.. Also wired the pump and relay ground direct to the battery but that didn´t work - when attaching the battery + the pump goes on with the ign off :s
                        When having the pump and relay ground to chassi everything works :s how come ?
                        • driftin jo
                          • Sep 2007
                          • 2222
                          The pump does not prime, the pump is started by the ECU when 28+ rpm is detected
                          during cranking.
                          • Carfreak
                            • Apr 2012
                            • 225
                            during cranking.
                            Okey, thnx
