Hello all,
I've been having issues recently achieving full boost (1.4bar) on my homefried 3B.
System airtight with new hoses all round.
In 3,4,5 gear on WOT the boost gauge climbs up to around 1.1- 1.2 bar where the needle will bounce around and only in 5th gear if you hold it long enough it will slowly creep round to 1.3 to 1.4 bar, again with the needle bouncing around.
Having scanned through the forum i came across the F96 altitude sensor thread and decided to test mine.
When tested for resistance using a multimeter i got the following readings-
1-2 - 1402 ohms
1-3 - Unable to get a proper reading as when the probes are connected to the pins i get an initail reading briefly then goes straight to 1 (short) i tried several times and the initial reading was sometimes really high then really low. i.e 2500 then 500
2-3 Same again across these pins, eratic initial readings then the meter reading 1.
I take it i should be able to get an accurate reading across pins 1-3 and 2-3 like i can across 1-2.
I googled the local atmospheric pressure and was coming in at 759mmHg
Would this explain my WOT boost problems.
Also where would be the cheapest place to buy one of these sensors?
Audi just quoted £109, eeek!!
Look forward to your reply guys.
Thanks
1-2 - 1402 ohms
Thanks
