.82 housing in a Ur.
  • DJones
    • Jun 2005
    • 2020
    Following on from Angus's thread i have now fitted the larger exhaust housing, and have included some pictures for reference.
    First picture is old v new..
  • DJones
    • Jun 2005
    • 2020
    The second picture shows why i also had to swap the turbine wheel to the 60mm wheel as opposed to the 56.1mm one.... mind you this would have resolved my explosive boost problem.... lol...
    • DJones
      • Jun 2005
      • 2020
      Turbo reassembled..
      • DJones
        • Jun 2005
        • 2020
        Then i had to cut a hole in the chassis rail to allow some clearance around the housing as it clashes with it when in combination with the RS2 manifold.
        The welding is not great but i had to do it with short blasts (spots) so as not to generate to much heat for the wax oil in the rail..
        • DJones
          • Jun 2005
          • 2020
          Some paint (no picture) then a layer of heat shield..
          All back together, not had a chance to drive it yet, hopefully get an MOT tomorrow and can report more....
          Edit: Forgot to mention i also had to slightly modify the down pipe, in particular the waste-gate flange as can been seen by the fresh weld you can just make out..
          • SteveH
            • 4460
            What do you think the new setup will make? I'd like to upgrade the RS2 turbo on my car, but realise the RS2 manifold will be a bottleneck.
            91 Modded 3B
            14 A6 Avant Black Edition
            • DJones
              • Jun 2005
              • 2020
              To be honest, i will be happy with what it had before just want it to be more progressive with slower spool up, it was to explosive previously.
              • djh
                • Jun 2011
                • 1622
                A 3071r would be the next upgrade for your manifold, should go well with one of them.
                @darren good work and keep us updated.
                • URquattroGus
                  • Aug 2007
                  • 547
                  Looking good
                  I reckon you could make 460-480 bhp with that combination as a guess.
                  Angus
                  (1984 ur quattro)
                  • DJones
                    • Jun 2005
                    • 2020
                    Originally posted by URquattroGus
                    Looking good
                    Ta
                    To be honest the manifold will limit it to 450ish which I am happy with, just want the spool to be less harsh.
                    • DJones
                      • Jun 2005
                      • 2020
                      Went straight through the MOT
                      Feels much nicer with the new housing, still aggressive but somehow much smoother and just keeps pulling without the flat torque curve i had previously.
                      Yep think i am sorted will get the map looked at but happy for now...
                      • jsws3
                        • Apr 2012
                        • 1174
                        Great news mate glad your happy with it .
                        Can't wait to get mine done .
                        • europeanme
                          • Oct 2005
                          • 3817
                          I've probably not read your project thread recently but what size did you go up from?....0.63?...
                          • DJones
                            • Jun 2005
                            • 2020
                            I went from .6ar housing (not even .63) with a 56.1mm wheel. Now has a 60mm wheel in a .82 Porsche housing, (KKK housing) in theory it's now a GT3071.82. Interestingly Craig at CR Turbos said he could fit a GTX compressor wheel at some point if I wanted... That would probably be the ultimate turbo for my set up...
                            • adam g
                              • Feb 2007
                              • 445
                              Ive just received a turbo from craig at CR same as your old spec with 56mm wheel k24 housing. Ill be interested to see how aggressive it is. My last blower was laggy as hell so looking forward to it
