AAN engine to ABY gearbox
could be simply the wrong release bearing!
measure from the back of the block to the point of the clutch fingers and i will measure my AAN one tomorrow for you
will try to measure inside the input shaft size too
Sean.1993 URS4 Avant Emerald Green 350+bhp
Drove to my work place and i took a few snaps today for you, hopefully be of some help
will pist when i upload em in a few minutes
here we go then, bit dificult due to lack of light and space to get in but did the best i can lol
height from back of ring gear/flywheel to tip of pressure plate fingers is approx 87mm .......... give or take
Hope this helps
interesting to know the AAN C4 cars have been fitted with spacer and without spacer. Does this mean that the AAN dualmass flywheel / clutch setup thickness has increased / decreased over time?
I still do not understand why this should be different compared to the ABY and ADU engine setups (similar bottom-end, 01E gearbox, and always a spacer in between).
The only difference there could be is in the UrS4/S6 gearbox version of the 01E maybe. Did the automatic, 5-speed and 6-speed versions of the 01E gearbox have different external features?Comment
this might cause problems with disengaging the clutch, i.e not enough travel mate
maby the thrust bearing is different, when i put my AAN in the A4 i hat to pull it in with a ratchet spanner, so took it apart and used the URS4 bearing (that was shagged) and it made a difference
just a thaught
My -95 S2 avant had the spacer so im using it with my AAN engine with sachs 707 clutchComment
Why
