G62 Coolant sensor problem
  • Carfreak
    • Apr 2012
    • 225
    Originally posted by UrS4boy
    Hello!!??
    No PM. No PN!
    strange, sent the PM this morning :s
    Ill send it again!
    • Carfreak
      • Apr 2012
      • 225
      Originally posted by prj
      If the sensor has an intermittent signal, and it is jumping around, then it can cause this.
      But before changing it, can be diagnosed with VAG-COM.
      Replacing it without prior diagnosis is usually not a very good idea, as 99% of idle problems are caused by different reasons.
      My code sayed short to ground so It could be the wiring or the sensor so I measured the sensor and it was bad thankfully
        Originally posted by Thuppu
        Can't belive it! It works, no stalling anymore, revvs goes down to idle nice and smooth, idles fine(except few missfires here and then). I changed the G62 today. Did buy a FAE 33030, not exactly expencive.
        Note the Bosch PN equivalent (previously listed):
        • Carfreak
          • Apr 2012
          • 225
          Can't belive it! It works, no stalling anymore, revvs goes down to idle nice and smooth, idles fine(except few missfires here and then). I changed the G62 today. Did buy a FAE 33030, not exactly expencive: http://www.ebay.co.uk/itm/Audi-90-10...-/290532166356
          That´s wonderful man!! Glad u fixed it!
          • Thuppu
            • 4115
            Yea, I could had the Bosch version ordered to tomorrow, was something like ~30 euro. But I wanted to test this today so I bought the FAE for 16,90 euro.
            • 220bhp
              • 2578
              • Home: United Kingdom
              #36
              Glad you fixed yoursBut replacing the sensor and the connector,has not cured my car completly,Idle still high,at 1050.Idle still occilates at 1450,drone still there at 2000, but not as bad.
              So far I made the car run a little better every time I do stff ,but I still han'nt cured it
              • Carfreak
                • Apr 2012
                • 225
                Sound like vakuum leaks to me.. Have u checked that the right connector is connected to the isv ?
                • 220bhp
                  • 2578
                  #38
                  Yes
                  • ericd
                    • Nov 2003
                    • 1240
                    Recently had this on a 3b (182k miles), ran fine for last 20 months with no issues, recently started with wavering idle. near stalling after warmup, intermittent throttle response, thought about either tps or G62, nothing in vagcom other than #532 (which relates more to the fact that i was idling/warming up the car for lengthier periods of time than usual)
                    anyway got a new G62 from ebay (VW heritage ?) for around £12 delivered, changed and now car back to normal...
