2.2l e85, hp goal 800hp, wich turbo?
  • |CL|NIKI
    • Jun 2008
    • 380
    • Home: Bulgaria Current: United Kingdom
    Originally posted by Mcstiff
    My mistake, 612whp HTA3582r..
    [YOUTUBE] does not work... http://www.youtube.com/watch?v=9kQJS71ZRdc
    I'm sure it does not make 600 from 4-8k but at 4k it is cooking and things are moving fast!
    Best achievement!!
    What setup You use and at what pressure?
    800HP 800++Nm
    • Mcstiff
      • Oct 2004
      • 504
      The car is Hank Iroz's formally of UT. He now has a 2.6l but at the time of the dyno he said:
      Originally posted by ShavedQuattro
      My engine configuration at the moment is the following..
      73k mile AAN block
      AAN windage tray
      ARP Main bolts
      73K miles main bearings
      73k mile rod bearings
      DM Forged connecting rods with arp 2000 rod bolts
      Stock pistons( I skimmed the tops of them to get a .040 piston to head clearance.. stock is .034)
      ARP head studs
      Rebuilt 40k miles ago 7a head with 240k mile valves, but otherwise stock ports, decked .025 to raise compression
      Supertech valve springs
      7a cams
      Cam Gear at 4 degrees retarded.
      Free flowing manifolds and a big turbo with fuel to match!
      1995 1PissedOff90sigpic1991 USDM CQ 7aT
      • |CL|NIKI
        • Jun 2008
        • 380
        That is almost nothing...Still hard to believe HTA35 can flow 450kW at wheels...
        What pressure?
        800HP 800++Nm
        • Pat D
          • Dec 2011
          • 748
          • Country: Australia
          Originally posted by x6rs
          want as good spool up as possible for reasonable money, ball-bearing is a must.
          looked a bit at garret gt40r, is there more or better alternatives(not precision turbos)
          Why not precision?
          ABY S2 stroker (work in progress)
          B5 1.8T quattro
          B4 2.3 (decommissioned)
          • Mcstiff
            • Oct 2004
            • 504
            What pressure?
            I'd have to hunt back through his thread >30psi for sure. It should be said that his 2.2 ultimately failed (broken ring land) after lots and lots of abuse.
            • |CL|NIKI
              • Jun 2008
              • 380
              #21
              Thats for sure. As for the boost - more like 33-36psi at list I think. I will try that very soon...
              For the thread - DBB GT4094r will flow 800hp.
              800HP 800++Nm
              • Thuppu
                • 4115
                Holset Pro55 830hp on a family sedan. I really wan't to see a dyno craph with 800hp from 4k... sure those will be ponies.
