Has anyone experienced issue that readings goes lower on coolant temp. gauge on highway ?
I've checked MFTS and found that grommet (p/n 4A0971876 - 4.71eur) is off the sensor.
I wasn't able to pull it back on the sensor, will do that during head removal, but I'm sure
that was a cause of this issue. But then I got idea to do it even better.. instead of grommet
to use heat sleave (photos attached), I have tested to fit it on old spare MFTS and to me it looks
perfect. If this sleave can protect till 650 Celsius I believe it will protect better from some wind as well...
