Just got upbto derby and I'm getting some intermittent boost.
One pull will be 10psi, next normal at 20ish. What should I check? Unfortunately I can't pull codes atm so doesn't make life easy.
I'm thinking...
Maf
N75
MFTS
Boost leak?
Waste gate
Knock sensors
Any other thoughts
Sent from my GT-I9300 using Tapatalk 2
I'm thinking...
Maf
N75
MFTS
Boost leak?
Waste gate
Knock sensors
Any other thoughts
This I think was because it would suck oil up past the rings on overun causing knock.
