Need help with some 3B and ABY/ADU differences
    Somebody on my home forum, quattroworld.com (UrS forum), wanted a primer on the progression of the RR, 3B, AAN, ABY and ADU. I have gotten some conflicting comments, e.g. the ABY has a serpentine belt accessory drive system (or does it?). Remember I am in Canada where we got ZERO S2s so no ABYs.
    Here is the post:
    Here is an Autoshow ABY cut-away showing a V-belt driving the PS/PB pump.
  • andy10v
    • 5996
    3B, ABY and ADU are V belt for power steering/brake pump, alternator and air con, only the AAN was serperntine.
    Sold ABY-stock
      Thank you Andy. That is what I thought but someone told me that the ABY used a serpentine belt system.
      • cooperquattro
        • Jan 2011
        • 815
        Aby has 2 belts!1 is v belt that goes to the pas,the other is a small serpentine that powers the alternator
        • shaun5
          • 1610
          Dont forget the air-con belt if you have got it
            I presume that the A/C belt is another v-belt?
              Yes
