Adjustable cam gear for 7a
  • Fredd
    • 41
    Building new AAN motor and putting 7a cams. Do i need adjustable cam gear or do i use original AAN gear? If i need it what do i put it on approximately fist start? Retard or advance? Same orientation as standard i guess. Want to make as little work possible for the guy mapping the car.
    Will run Vems with standard hall sensor
    Hope this is enough information
    Audi S6 1996 Red
    Audi S2 "RS2" 1995
    BMW X5 3.5 SD
  • Fredd
    • 41
    Anyone ? Necessary or not ?
    Audi S6 1996 Red
    Audi S2 "RS2" 1995
    BMW X5 3.5 SD
    • Thuppu
      • 4115
      Yeah, I belive you need the adjustable cam gear for the exhaust cam and the adjustable cam sprocket for the intake cam to setup the cams properly. With stock marking you get a quite laggy setup... You can first try to adjust something between 0,8-1,2mm for the exhaust cam and 1-1,5mm for the intake cam at TDC.
      • Sleeper_Avant
        • 2372
        if using AAN/ABY ecu then you need cam pulley with hall sensor, Dahlback do adjustable ones.
        1993 URS4 Avant Emerald Green 350+bhp
        1991 Ford Sierra Sapphire 4x4 in Magenta
        BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
        • Fredd
          • 41
          Thank Thuppu
          Will buy both gears then
          Audi S6 1996 Red
          Audi S2 "RS2" 1995
          BMW X5 3.5 SD
