Boost test (leaking turbo)
  • nip
    • Apr 2006
    • 1786
    • Home: United Kingdom Current: Abu Dhabi
    Well ive boost tested it yet again today but all i hear is air p155ing out of the turbo cant feel any air but can hear it, also it wont hold any pressure what so ever.
    My car being suffering with being down on power it boosts to 20-25psi but has no real go to it(feels like just blowing hot air). Also running standard power turbo ect.
    Any ideas???
    cheers nip
  • martinws
    • Oct 2008
    • 917
    Have you blanked of the small diameter hose going to the Lower wastegate chamber before testing?
    • nip
      • Apr 2006
      • 1786
      I tested it with it still on, then blanked if off but still was the same
      • driftin jo
        • Sep 2007
        • 2222
        Any ideas???
        cheers nip
        Your running a standard turbo ? At 20-25 psi ? Thats way over what chipped standard
        set up should do !
        Standard RS2 is only 21 psi .
        • nip
          • Apr 2006
          • 1786
          set up should do !
          It's also chipped (forgot to add that) , it always run about 20-25 psi
            But it can be chipped to run 28 psi.
            • driftin jo
              • Sep 2007
              • 2222
              Yes but this is a stock S2, so chipped will only do 21-22 psi max before it's just a
              furnace of hot air.
                Check the bolts holding the cold side on, mine were loose. I took them all out and re-fitted with blue loctite. Also check the hose from the cold side to the WGFV is not split and the WGFV is not cracked or broken, I've had this too. Best to pull the hose of the WGFV and plug the end to test (don't drive it like this though!)
                Blowing like mad and not making power can also be the MAF connector corroded and the vac line to the ECU leaking.
                • nip
                  • Apr 2006
                  • 1786
                  Cheers newsh, il check them tomorrow I also took the pipe from the n75 to the turbo off pressure tested it then put my finger over the turbo nipple and it held pressure, it seems like its leaking somewhere in the middle of the turbo I can hear the air bubbling in the sump.
                    Ok, if it's bubbling the oil then that's fairly normal Could mean your turbo is getting tired though..
                    • nip
                      • Apr 2006
                      • 1786
                      If it bubbles the oil in the sump so that means air is escaping through the turbo seals then, also if the air is leaking surely that can't be normal can it?
                      • nip
                        • Apr 2006
                        • 1786
                        Pressure tested it again today, still the same it seemed as the turo was leeking before, its more like the bottom of the wastegate, if I block the pipe going into the wastegate from the n75 it doesn't leak so does that mean the gate is knackered?
                          It does mean there's air getting through the wastegate valve guide, however this is less of a problem when driving as there's boost pressure one side and exhaust pressure the other side to balance it somewhat. I would just take the top off the wastegate (6 small nuts) and see how much you can wobble the top of the valve from side to side. If it's really bad then get it refurbed. The leak will tend to make the car boost more than it should.
                          • nip
                            • Apr 2006
                            • 1786
                            Cheers newish, I did that today it does wobble allot, il replace the gate and see if it cures it.
                            • prj
                              • Mar 2010
                              • 6308
                              Every single one of these gates leak to the exhaust and it doesn't matter because it seals up when hot.
                              Just make sure the membrane is not shot.
                              I would measure the compression in the engine, because it's been knocking like crazy if it's running 25 psi on standard turbo.
                              I'd say the rings are shot because of det and it needs a rebuild.
