Unplugging brittle coilpacks
  • Ian Simmonds
    • Jun 2005
    • 2858
    Any advice on unplugging and swapping around coil packs? The electrical connectors are really brittle and I'm fearful to get it heavy handed and bu??er the thing up.
    93 MTMS2 Avant
  • Razzo4112
    • Mar 2011
    • 66
    i had the same problem when changing mine. i ended up changing the lot. it was extremely difficult to get the connectors off without braking them.
    Ryan
    I Can........But i probably wont
    • jade
      • Jan 2005
      • 1811
      As far as I am aware they do not unplug they come with wires to wire in
      RS 2 580HP
      • Razzo4112
        • Mar 2011
        • 66
        that might be why they wouldn't uplug
        Ryan
        • Ian Simmonds
          • Jun 2005
          • 2858
          Okay, so where do they 'disconnect' to be able to swap coils over?... Beru coils for the S2 are available separately, it's not a cut and soulder job is it?...
          93 MTMS2 Avant
          • mcandmar
            • Apr 2004
            • 5118
            There is no connector on them, so when you buy new coil packs like the berus you have to solder them onto the plugs.
            91CQ20v - Gone to a new home
            93UR-S4 - The Magic Carpet
            94S2Bus - The Emerald Express
            • Ian Simmonds
              • Jun 2005
              • 2858
              Ah, right, got ya... thanks....
              93 MTMS2 Avant
