My aby coupe has started playing odd....
when boosting to near 1 bar, the engine suddenly cuts all power (doesnt stall). once this happens the engine will continue to "cut out" at 0.5 bar until the engine is re-started. once re-started it will boost to near 1 bar again then continue to do the same at 0.5 bar.
Can any one explain? is it a safety feature on the ECU?
Thanks in advance
Thanks in advance
