Oil consumption / Head rebuild recommendations
  • pasbogdan
    • Sep 2009
    • 1160
    • Country: Romania
    Acces to valve feet no,but hold valve from upper tail and check play in it's upper part,even with a dial gauge.But first need to check play in the upper part on a good guide on a spare head because tolerances measured at the tail may not be as measured at the other end.But worth it?I think not.
    • andy10v
      • 5996
      There is a tool kit for in situ that uses a fitting in the spark plug hole and compressed air, along with a tool to compress the valve springs allowing seal replacement.
      Also the "ghetto" method of filling the combustion chamber with rope.
      Something like this
      Choosing the right domain name can be overwhelming. Our personalized customer service helps you get a great domain.
      There are a few vw 16v guides out there with a quick google.
      Sold ABY-stock
