Over the course of the trackday, I used about 0.5 to 0.75 litres of oil and this is a trend that I've been noticing of late, when doing 'demo runs' or spirited driving on the road, not enough that I'm panicing but it's certainly a little more than I've been used to replacing.
The catch tank was empty, so it's not going through the breather thanks to the swirl pot
I noticed that there was a puff of oil from the car after idling / sitting hot (my Dad was driving) - stem seals?
The turbo was checked and fitted witin the last year and I don't think it's that.
There could be a leak in the system but with the puff from the exhaust, that will not be the only cause.
I think it could be stem seals, as the engine has done 170k now and that seems to be a good innings for the original seals!
Any other suggestions?
Any recommendations of somewhere to change the stem seals in situ (I'm also wanting to fit new tappets or clean the current ones at the same time). JP?
i think mine is to do with flooding the PCV from binning it off several roundabouts. Didnt do it once on the trip up and back to Ipswich this week but who knows
bite the bullet and do it right
