Hi Guys
anyone got a timing diagram for the cams on a V reg A3 1.8t AJQ engine code, i have the cam belt diagram but not the one to time up the cams with each other any help would be great
Was sent this so I am sharing it with the community as this seems to be the most confusing topic when doing a 20V Rebuild.Thanks to whoever did it up
Quote, originally posted by CYLINDER HEAD REMOVAL & INSTALLATION »
CAUTION
Cylinder head removal should not be attempted unless the...
two stamp marks on inside of again rules should point towards each other level with head. there should be 16 chain links between each stamp mark. dead easy mate. if yours has vvt replace tensioner and gasket save job later. they get noisy over time.
Oh yeah you need to compress tensioner with above tool. My advice fit inlet cams attach exhaust cams to chain in correct position and swing them into position and tighten bearing caps in order etc. Pretty straight forward just a touch fiddly
