A3 1.8t Cam Timing
  • bigcooler
    • Jan 2009
    • 229
    A3 1.8t Cam Timing
    Hi Guys
    anyone got a timing diagram for the cams on a V reg A3 1.8t AJQ engine code, i have the cam belt diagram but not the one to time up the cams with each other any help would be great
  • speeding-g60
    • Aug 2008
    • 1186
    i dunno about that engine code, but here in the USA all the 1.8T 20v are timed the same.
    Was sent this so I am sharing it with the community as this seems to be the most confusing topic when doing a 20V Rebuild.Thanks to whoever did it up Quote, originally posted by CYLINDER HEAD REMOVAL & INSTALLATION » CAUTION Cylinder head removal should not be attempted unless the...
    • Monkeymagic
      • Mar 2012
      • 3419
      two stamp marks on inside of again rules should point towards each other level with head. there should be 16 chain links between each stamp mark. dead easy mate. if yours has vvt replace tensioner and gasket save job later. they get noisy over time.
      • Monkeymagic
        • Mar 2012
        • 3419
        i hate phones. should read on inside of chain pulleys.
        • mcandmar
          • Apr 2004
          • 5118
          Make sure you have the 3366 tool, other than that its just a fiddly job.
          91CQ20v - Gone to a new home
          93UR-S4 - The Magic Carpet
          94S2Bus - The Emerald Express
          • Monkeymagic
            • Mar 2012
            • 3419
            Oh yeah you need to compress tensioner with above tool. My advice fit inlet cams attach exhaust cams to chain in correct position and swing them into position and tighten bearing caps in order etc. Pretty straight forward just a touch fiddly
            • bigcooler
              • Jan 2009
              • 229
              thank you guys for your help i will get on it as soon as i can hopefully i goes to plan
              • AndyP
                • 6049
                Any good?
                • bigcooler
                  • Jan 2009
                  • 229
                  amazing just what i was after thanks
