Priming fuel system.
  • re2500
    • May 2007
    • 2185
    Is there a recommended method of priming the fuel system after fitting a new filter and some of the fuel line. (Finally got round to removing the 10v fuel pressure accumulator next to the filter).
    I cranked it over for a while last night, battery wasnt great so it ran down eventually.
    Is this normal, when ive done work on fuel lines in the past its not taken this long to fire up.
    Should i be cracking a fitting somewhere to help the air out? I just figured it would self prime letting the air out through through the return.
    Knowing my luck something completely unrelated has gone wrong at the same time and im barking up the wrong tree.
    Also i was thinking about the filter layout, surely due the the horizontal mounting of the coupe filter there will always be air trapped in the top?
    "Difficult is worth doing"
  • prj
    • Mar 2010
    • 6308
    Just crank it until it starts.
    • mcandmar
      • Apr 2004
      • 5118
      From dry it should prime itself within 10-20 seconds. What i usually do after working on the fuel system is remove the plastic cover off the fuel pump relay and manually close the contacts with my finger. That way you can check for leaks and hear the air being worked out of the system.
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
      • re2500
        • May 2007
        • 2185
        Ta! i'll give that a go!
