Ok. I have had this problem for a long time. But I think is just not one thing.
Engine behaves a little bit strange, the problem is that not always.
Things that happen:
1. I han hear a buzz noise from the right side of the car in the back. Only when I am accelerating from stand still very gently. After trying to figure it out for some time I have noticed it is only when fuel tank is low, so I think it is the fuel pump.
2. Sometimes I have idle problems. Specially when I enter the city after a motorway run. It will happen for around 5 minutes. When I stop revs drop to around 300 rpm, sometimes it even stalls.
3. Power delivery is not very good. When I accelerate hard, around 3500 rpm I feel as I don't have all the power there. The sensation is as the overboost protection was going to engage. I dit fit the Samcos and IC O-ring mode and since then I have not had any overboost protection kicking in, but I still feel the power is not there. The stange thing is that somedays the power IS THERE and the car really flyes.
Please some suggestions.
I am going to start the engine rebuild now as I have all the bits so this is going in (RS2 IC already in) If I need to change something else this is the time.
- RS2 IM, Turbo, EM, Cams, Injectors, Fuel preassure regulator
- Marco's Downpipe and a new Lambda I ordered (std)
- Oil pump, Water pump, Timing belt (Std)
- Fuel pump (Std)
Could the MAF be my problem? I am not changing it
I thought all my engine problems where cause by and air leak, but now the Samcos are in, the engine is running better, but not perfect.
Regards and sorry for the long post
Rafael
Things that happen:
- Fuel pump (Std)
,Rafael
