well , i have fitted this system in my S2.
does someone here uses a system like this in his cars?
what are the main advantages? firstly,i am going to use it " as a cooler" ..without remapping the car...
depending of the aquamist jets flow , how many degrees less can cool the IAT?
and about tuning.... for what reason can you map the same engine with much more agressive spark timing? only because the lower IAT´s? or does it have high octane anti knocking features aswell?
according with what PRJ said me, is it possible to add +15/20% of the normal power in an engine with 98 octane fuel?
and the spool up the turbo would be better true? because the more agressive timing once mapped properly...
i would like to read your own experiences guys
