Nah. No hoses.
OK, got it wrong. I 'thought' it was a 51 row cooler but it turns out to be only 44. I don't know why I thought it was more. Anyway, dimesnions without moutning lugs and hydraulic fittings is 165 x 50 x 345 mm. I can bring it up if you like. Got it for £30 so it would be rude not to use it. There is room to get fittings in but it is quite tight and I think I can do it without removing the rad ducting. Then again, the rad ducting is a PITA when it comes to changing the thermostat and mine seem to go every 6 months or so.
